Stupid, trivial muppet problem with tyre dust caps
Old 08-25-2017, 11:09 AM
DaveJessop's Avatar
Default Stupid, trivial muppet problem with tyre dust caps
I bought some metal valve dust caps to match the bodywork and I can't undo one of them - anyone have any tips to release it without using two pairs of pliers and damaging the rubber valve?
Yes, I'm a muppet
Old 08-25-2017, 11:52 AM
JagXSE's Avatar
Try heating with hair dryer or hot water to see if one part expands, allowing you to unscrew.
DaveJessop (08-25-2017)
Old 08-25-2017, 12:48 PM
DaveJessop's Avatar
Thanks - I'll try the hot water - don't have a 60 foot extention lead
Old 08-25-2017, 03:31 PM
Dell Gailey's Avatar
Metal ones are the reason tire shops remove and chuck them in the garbage and replace with plastic. The tend to corrode on the stem. I have green to match the growler tire inserts, but am changing to red growlers soon and will be looking for red caps.
Old 08-25-2017, 03:34 PM
Maybe these, lmao!!
DaveJessop (08-26-2017)
Old 08-25-2017, 04:41 PM
Alfadude's Avatar
Have t=you tried turning them with pliers or an open end wrench a little? Maybe just that extra torque you can't get with your fingers would be enough. Try spraying some penetrating oil in there carefully and let it sit a bit.
How did you put them on in the first place? I have had metal caps in the past and never had an issue ever.
Old 08-26-2017, 06:50 AM
DaveJessop's Avatar
I probably either over tightened one of them or there was some crap on the thread and it somehow sealed it
Good suggestions guys
Old 08-26-2017, 10:28 AM
JagXSE's Avatar
if you get off, before reapplying, apply some Vaseline on the thread.
Old 08-28-2017, 02:32 PM
wa3ra's Avatar
Mine came with a small wrench, but a dab of LITHIUM based lube will keep them removable.
Don't use a petroleum based lube; it will attack the rubber seal!
DaveJessop (08-29-2017)
Old 08-31-2017, 09:51 AM
DaveJessop's Avatar
Finally!!
After 3 or 4 applications of penetrating oil over a few days I put a rag around the valve to hold it tighter and used a socket wrench on the dust cap
The thread on the valve was very white and powdery so who knows what was on there
