Sub Install...
yes indeed i do, there is a big bunch of wires that are shoved through the firewall. If you look down there with a flashlight you should be able to see them. This is where you shouldnt put the cable through. Now if you look a little towards where the steering column is i believe there is a soft rubber grommet that you should be able to see from the engine compartment and through there on the other side (cabin) there is some foam insulation. I would drill a small hole through the rubber grommet and push the cable through there. Make sure to make the hole smaller so you get a tight fit with the rubber and the cable. The grommet is not an inch or so it is pretty big i would say about 3 to 4 inches. if you cant find it let me know, but a flashlight is a must!
Just found out the 02 models dont have fold down seats but I found a way to get them back there. Thanks anyway!
