Symptoms of a MAF (Mass Air Flow) Sensor?
uumm could it be the computer now? Should i delete the code so the computer will say "ITS FIXED" I can use it now, or is it totally another issue?
P0174 is Bank 2 combustion too lean. Did you check for air leaks at the intake manifold O-rings or intake tuning valves?
Read this post and all the links in it...
https://www.jaguarforums.com/forum/s...ead.php?t=3726
If it's the IMTs you will probably be able to hear a hissing sound. Also check the PCV hose for a bottom side split and the brake boost check valve for deterioration. Search the 0174 code on the forum and you'll get a ****load of information. Being an '03, if your X-Type hasn't had these three things replaced, they will need to be. The new IMT o-rings are green, the new PCV hose is "ribbed" (not for pleasure) and the brake boost hose has a heat sealed check valve.
No the intake does not have to come off to replace them. Here is a pic:
https://www.jaguarforums.com/forum/s...ad.php?t=16235
i have a problem with my car stalling, does this mean that i might be having a problem with my mass air flow sensor? if it is, how much am i looking at?
I had to take my X type to an Import car shop and they did a computer diagnostic ($98.00) about all and my MAF sensor is bad and they said that the computer needs to be restarted after the install, they will do the job for me for $305.00 I am wondering if I can replace the Maf sensor myself. Also my check engine light it is not present any more after said diagnostic was performed, so I do not know what to do, any advise???
Yeah that was happening, the code was P0174. I replaced the MAF sensor and the "Check Engine" light is still on.... Less of the symptoms you mentioned but they still do happen but not as much.
Received 3,913 Likes
rf69, yes, you can replace the MAF yourself. It is nothing more than 2 screws and an electrical plug. If I remember right, you only need a phillips screw driver. Worst case, you will need to spend $10-15 on a set of torx screw drivers (good to have with modern cars anyways). Undo 2 screws, undo the plug, pull the MAF out of the intake, toss out the old, put the new in the hole, install 2 screws and make up the electrical plug. The only additional step I would say is to then remove the negative battery cable and let the car sit for 5 minutes. This will erase any memory for the ECU. After the 5 minutes, reconnect the battery lead and run the car. Your problem should be solved.
On a side note, when you disconnect the battery, this will erase the programming for the power windows. To reprogram, lower 1 window at a time, holding the button down till it reaches full travel and then continue holding the button down for an additional 3 seconds. Raise the window and hold the button up till the window is fully closed, continue to hold the button up for an additional 3 seconds. Repeat for the other windows.
muad'dib (07-18-2022)
My car did a similar thing, i replaced upper and lower gaskets and spark plugs- and it was fixed- not hard at all - takes a cple hours the first time - you may want to consider changing spark plugs if you haven't done it in a while (dbl platinum only) as if you have the intake manifold off anyways. there is a great post on the forums on how to remove the intake manifold.
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
I replaced in my X type the sparks plugs with Premium Bosch Iridium and it is written on the box DO NOT GAP so better for me but after a while driving my car around the block I noticed my engine hesitating like dying and the check engine light on I opened my hood and heard a hissing sound coming from the upper intake or vacuum I red some posts here and I believe it is the o- ring because I already replace the MAF sensor and the check engine light disappeared, Anyways I took my Jag to an Advance Autoparts shop and the codes said misfired cylinder 2 and 4 at this point I do not know what to think I am going to replace the O- ring and them see if I have a bad ignititon coil
Open the hood, and stand on the passenger side of the engine compartment. Look at the intake manifold (the heavy metal object on the top of your engine). On the side of that object nearest you, you will see two black circles that each have wires connected to them and two screws on opposite sides of the circles. One sites above the other. They slide out after you take the screws out and would slide directly towards where you are standing. Hope this helps.
Don’t know if this is relevant or helpful, but I had a problem with my Range Rover which manifested itself by a gradual (over time) creeping up of the speed at which the ZF box would drop into top, particularly on light throttle. It usually will do so at about 60kph, but crept up to almost 80kpk.
I took it in (twice) to the franchise dealership who charged me $100 each time to put it on ‘testbook’, and they absolutely insisted that the problem was a mechanical fault in the box which would have to be removed and overhauled. $3800 later and the bloody problem reappears. The damned car struggled to pull a household trailer over our gateway bridge (1.67klms long rising 78m high over the Brisbane river).
In frustration I took it in to my local mechanic’s workshop, and he put ‘autologic’ on it. Took him less than 5 minutes all up to tell me that the MAF was faulty. The computer was reading ‘insufficient power’ and holding back the gear changes to compensate. $396 & 2 minutes to fix. I’m about to drag the Franchise Dealer into Tribunal to get my $3800 back.
Cheers,
Languid
Cheers,
Languid
KarimPA
09-12-2015 08:15 AM
