Tailgate Stoplight not working
Received 3,903 Likes
JagAlan, based on what you are describing, your problem lies in 1 of 2 spots. You either have a bad 3rd brake light (ie, the high mount light) or the ground wire has become disconnected for the 3rd brake light. So, if you can, remove the 3rd brake light and see what the wiring looks like. You will also want to do a detailed inspection of the orange/green wire coming off of the 3rd brake light as that is the power wire that is getting power from your other 2 lower brake lights. If the lower brake lights are not working, then that changes things completely. But, you will also want to look at the black wire coming off of the 3rd brake light to make sure that it is bolted to the body there near the 3rd brake light.
If you have any questions, let me know. Describe it as much as possible or take a pic and post it here.
philwarner
09-05-2015 10:05 AM
