Taillight bulb out, but brakes, reverse work
Old 02-09-2011 | 03:27 PM
TD26's Avatar
Default Taillight bulb out, but brakes, reverse work
My right rear taillight is out. The bulb works when I hit the brakes, but the taillight just does not come on when I turn on the headlights. Any fixes? I changed the bulb and it didn't work...
Any help is appreciated!
Old 02-09-2011 | 06:40 PM
Thermo's Avatar
TD26, try removing the back plate to the tail lights, removing the bulb in question and then using a pencil, take the eraser and rub all the electrical connections really good. Concentrate on the two at the bottom (don't need to worry so much about the one on the side). This will help remove any corrosion that may have built up there.
If that don't fix your issue, then you will need to pull out a multimeter to do some checks. How you feel about using a multimeter? I can step you through the rest of the things from there.
Not to ask a silly question, but did you get the correct bulb for the location. The wrong style bulb can lead to some interesting conditions.
LarMan (12-29-2014)
Old 02-10-2011 | 03:47 AM
Mephiston2k's Avatar
Check for loose connections, check the fuse. Go from there really... try a bulb you know that works and so on.
Old 02-10-2011 | 09:14 AM
TD26's Avatar
Thanks for the help. I try these suggestions and let you know how it goes. Really appreciate it!
Old 02-16-2011 | 09:27 PM
TD26's Avatar
Turns out it was just a fuse. Thanks for the help!
LarMan (12-29-2014)
Old 12-29-2014 | 10:21 PM
LarMan's Avatar
I got the same problem on my 02 x type. I have the passenger side parking light, as well as the rear passenger stop/tail light, and tail light not working.Which fuse should i replace?
Thanks!
JarodL
03-07-2024 02:39 AM
Robert1968
06-24-2017 12:16 PM
johnnie ryall
10-19-2015 10:44 PM
tberg
09-07-2015 08:32 AM
XFR_Gold
09-02-2015 01:24 PM
Quick Reply: Taillight bulb out, but brakes, reverse work
