is the temp level normal
today i was stuck in traffic for about 20 min. my temp gauge went all the way to 3/4 mark. i have never seen it do that before. i actually switched the car off. then when i turned it on and drove it went back to its normal spot, just below half. is that normal? i checked the coolant in the little tack its on max.
"Normal" is a hair below half. Always. If it spiked up on you, check for leaks in the coolant tank (tends to crack around the nipple where the rubbre hose connects at the top of the expansion tank,) or check that your radiator fans are running properly - stuff like that.
If there's something going on you should see that behavior again.
i don't think my fans i working. i turned the a/c on and the temp gauge was on its normal spot, just below half mark and the fans didn't run. any advice
abonano
25
09-25-2015 10:43 AM
