Temporary Instrument panel failure
Hi folks, looking for some advice on whether my problem is indicating a future permanent failure or just a glitch.
Started car up tonight and none of the analogue instruments moved - speedo, rev counter, fuel and temp. The message centre was fine. Drove car for 1 mile, stopped and restarted - same issue. Drove for ~4 miles stopped, restarted and instruments all fine.
Anyone else experienced this and know what the likely cause is? Car has no known other issues.
For reference it's a RHD 2002 2.5SE manual with 98k miles on the clock.
Cheers,
Grant
Cheers,
Grant
Cheers,
Grant
Cheers,
Grant
This malfunction has never happened again, so I can't really say what caused it.
this happened to me before. was driving back to work on my lunch break one rainy day, looked down to check speed, 0 mph, 0 rpm, no lights... pulled into work and popped the hood. apparently i had closed my hood with the cover of the "under-hood" fuse panel on top of my battery box cover. i was checking fuses and had the cover off, forgot to put it back on and closed my hood. well a little water got in there and thats why it happened to me. hasnt happened since. -stevis05
WTB[NorthEast]: Driver door splash shield
convincor
10-01-2015 05:19 PM
2003, 2004, center, cluster, failure, instrument, insturment, jaguar, lights, malfunction, message, panel, problems, type, xtype
