Terra clean for X Type 2.2 Diesel 2007
Hi
Would appreciate you views . I had the dreaded limp mode happen to me the yellow coil light illuminated I have recently had a reconditions activator and thought it may be that again took to my trusted garage the mechanic checked the activator out its Ok but he said the turbo feels a bit stick reconnected give it a squirt of WD40 vcleaered the code and suggested a Diesel additive to clean the system I have also driven it up the motor way at high reeves to clear out .It seems to be OK . the Guys at work have mentioned a Terra Clean it's about £120 will it work or am I wasting my money .
Mine was terra cleaned and it only really improved the smoothness, EML was on before and after, emissions tested before and after were higher after.
If it were me, I would change to using super diesel
Then additives quarterly as it will be a while before those cost £120
Paul M P (01-26-2016)
allnlu
01-20-2016 08:56 AM
