Thermostat housing o-ring?
While under one of our X-Types today I noticed a very minor coolant leak at the thermostat housing and I'm going to guess that it's likely coming from the flange.
Does anyone have the part# (OEM, Dorman, etc.) for the o-ring? It appear that Jaguar wants you to buy the upper radiator hose assembly (that'll be the day that I spend $100+ to repair something that an o-ring or RTV will fix!).
TIA
TIA
O-ring failure is a very rare occurrence with the cooling systems components. Unless it was originally installed incorrectly or the fasteners have come loose it is unusual.
Most likely you have a crack in one of the components. The only way to isolate is to due a cold pressure test of the system.
G'day Blown Kitty,
What I would do is hose off all avidence of leaking coolant and then drive the car for a while and have a good look around under the hood particularly around the front of the engine to determine where the leak actually is. In my experience it is unlikely to be a dodgy 'O' ring or loosened bolts.
When my car leaked it was a cracked fitting with leaking coolant running down onto the thermostat housing.This fitting is as Jaguar call it 'Top Radiator Hose' or P/N C2S43430 or # 7 in the above diagram. It is the 'T' piece that cracks and leaks but you can't just buy that piece separately it comes with several pieces including a thermostat.
If it is the 'T' piece you may be able to repair it with some sort of epoxy but I have never had any luck with this sort of repair as the internal pressure of the cooling system eventually forces the epoxy loose and the leak is still there.
When I did my repair I bought the whole thing, as there is no choice, and replaced the lot and have had no problem since.
Cheers,
Jeff.
Cheers,
Jeff.
G'day Blown Kitty,
Cheers,
Jeff.
Cheers,
Jeff.
I'll take a closer look around the area, I only discovered the leak while replacing the #2 bank upstream o2 sensor (and that was fun..).
watto700 (02-02-2021)
Dirk Bailey
12-08-2010 08:10 PM
