Three buttons under sunroof button
There are three buttons under the sunroof button, each one having one, two and three dots on it. What are they for? Now, the down arrow on the sunroof button doesn't work, neither does my sunroof - so I didn't expect the three buttons to work for me to notice anything.
If its supposed to do something and it doesn't - is there a way to fix this?
Thank you. (And I already tried the whole " hold the sunroof for 30 sec. procedure, and it didn't work lol)
The 3 buttons are for 3 garage doors, if you have 3 separate garage doors with opener. Or (1) for your home, (1) for your vacation home & (1) for your mistress garage door ;-)
On a serious note, if you have a home lighting control system (ie Lutron, Lightolier & others), you can program one of the buttons for opening up the light in the hallway, living room & kitchen. It can also be programmed when you leave to turn off all the lights.
For the sunroof, check the fuse if its not working at all. You can also try disconnecting the battery for a few minutes & hopefully it reset what is keeping it stuck. There's quite a few thread just do an advance search.
philwarner
28
07-11-2017 10:21 AM
