throttle position sensor wiring
I have a 2003 X-type 2.5 that has the 4 wires pulled out of the throttle body position sensor. I would like to know if anyone can supply the proper wiring color sequence from top to bottom? The wire colors are black/green, brown, yellow and orange/yellow. Please help!
Chris, I am not sure which wire is on top, but the color sequence is black/green, yellow, brown (are you sure this isn't purple?), and orange/yellow. Looking at how Jaguar normally numbers their plugs, this would put the black/green wire on the bottom. Hope this gives you the info that you need.
chrismc50 (06-29-2014)
Aus V8S
11-13-2015 11:01 AM
