Thumping feeling under car
I can feel a vibrating thump from the pedals and it transfers over to the passenger side. I checked the links and bushings because I recently changed them. They still look good and tight.
Possible strut mount failure? How can I properly check the bushings and links. I pull them with my hand but no movement.
Yes, they were supposed to be OEM. The ones that I am changing myself this time are in Jaguar bags that I ordered from my local dealer. The mechanic was supposed to replace with OEM. Most likely they were cheap ones. I don't want to say he didn't do the work, maybe he did. It just didn't last a week if he DID.
Alright, I gave it my first go and unfortunately it didn't go in my favor. I cannot for the life of me figure how to loosen these bolts. I cannot justify if these were ever removed previously. I removed the 21mm & 10mm bolts that hold the rear sub-frame and it came down less than 2 inches. I can however reach the fasteners which I believe are 13mm bolts, but they are not loosening. Any advice from someone who has done this before?
Should I remove all the subframe bolts to lower the subframe further? Will this cause an issue later?
