Ticking sound in engine then power cuts
I recently brought my jag xtype really don't know to much about them looking for some help..this is my first car was happy to be buying it and things were fine until I was working on changing the head lights when I turned the car over and began to hear a ticking or tapping sound from the engine..was driving about 40 mphs trying to get it to a shop when the power cut right off all lights and gauges went expect the blinkers..and I couldn't really move the wheel to get it to the side of the road..i also noticed my battery cover was riding up against the pullies and belts on that side but was still on track and working fine so I ruled that out..it sounds like its coming from the passenger side of the car I don't know if its a top or bottom end tap or knock was hope I don't have to replace the whole engine
Thanks for and insight and feedback
Thanks will do and will keep you guys updated..I've read and heard great things about the jaguar forum family..again thanks for the insight help and knowledge
Po-300
Po301 cylinder 1 misfire and 2
303
305
306
P1316
Po116 kit range
Map sensor 1108
1646 lenor control chip
P1000 obd system not complete
P1108
1646 o2 sensor
Seems like a lot of missing. Look at coils and plugs.
Dumping raw gas into the exhaust could cause other errors.
0116 check coolant level.
1108 look for a bad connection or wires that got warm and grounded.
1646 O2 sensor bank 1 If you are lucky once everything else is fixed this will go away. Raw gas in the exhaust caused problem maybe.
Everything fixed listed before o2 sensor)
BrentGardner
28
04-26-2024 03:08 AM
