Tire Pressure Monitor info, MUST READ!!!
Old 01-11-2009, 05:19 PM
Real_Tech's Avatar
Default Tire Pressure Monitor info, MUST READ!!!
New SSM from Jaguar, "After reviewing tire pressure monitors returned for warranty replacement we have found that installation of metal valve caps has caused breakage of the valve stems and will not be covered under warranty. Corossion between the metal cap and the aluminum stem is causing seizing. Technicians are advised to remove any metal valve caps and replace with gray plastic caps installed at factory."
If you have metal caps and they don't want to come off try a little heat from a micro sized butane torch being careful of the wheel and damage to the valve stem seal. It doesn't take much heat and has been working for me. I've replaced several tire pressure monitors for this problem.
Old 01-11-2009, 05:44 PM
BuckMR2's Avatar
Default RE: Tire Pressure Monitor info, MUST READ!!!
Went from metal back to plastic because of this.
Old 01-11-2009, 05:49 PM
Thanks R_T, that one went in my notebook. But you probably just ruined a nice Sunday for some guy in Hongkong making chromeXF monogram valve caps.
Old 01-11-2009, 06:01 PM
Dennis's Avatar
ud
I don't have the TPM system..
Old 01-11-2009, 06:15 PM
jvegas's Avatar
ORIGINAL: JagtechOhio
toronadomike
08-07-2022 03:41 PM
Sprayall
05-30-2021 08:13 AM
dsnyder586
04-04-2019 02:38 PM
carcycle
09-07-2015 10:22 AM
Sprayall
09-03-2015 07:49 PM
Quick Reply: Tire Pressure Monitor info, MUST READ!!!
