Tizz from drivers door
ever since I got my car there has been a tizzing / rattle from the drivers door. The dealer has tried to fix this a few times under warranty and has wrapped the wires in foam. But still the noise is there. The car is out of warranty now so am thinking of taking a look myself. Anyone else experienced this noise?
Guest
Posts: n/a
more info please....
is this when the car is parked or moving? if moving then at what speeds?
window up or down?
stereo on or off?
elbow on the armrest or not?
is there any place you can put pressure on the door panel to stop the noise?
The door panel comes off fairly easily but ideally you have an idea what is happening before you take it apart.
window up or down?
stereo on or off?
whilst driving, but window etc makes no difference. Have not been able to isolate exactly where by putting pressure on door.
As you say taking the panel off is easy enough but as the dealer has tried all the obvious things already there is not much point pulling the panel unless I have an idea as to where to start looking.
Of course the noise may in fact not be the door, but as best as I can work out that seems to be the area.
cheers
Darren
cheers
Darren
Rivs if you got paperwork for the fix I'd take it back to them and the paperwork shows that they've worked on it before. At gm they make an account for everything that your car comes in for. Every complaint you make is documented so if you did have a problem and they couldn't fix it show that it happened before the warranty was up...I'd try this at least if the dealer isn't forever away...How long ago did you have it serviced for the problem til now???
99xk8guy
06-05-2023 06:28 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
