Tranny fluid leak?
So I was doing an oil change and I noticed tranny fluid on the drain plug. I wiped it off and went for a drive, put the car back on the lift and noticed fluid leaking from the seal in-between the trans and transfer case.
Anyone dealt with this? If yeah, what is the gasket called? A local mechanic said I might have to rebuild the trans if I remove that seal. I think hes trying to get more money out of me. So the question is, what route do I take? Take-in to consideration I want to keep the car.
It's a 3.0 automatic
The seal is a thin 'O'ring (C2S5132). It is on a flange that is part of the transfer case so the CV axle shafts need to be removed and the splined shaft displaced to move the transfer case from the gearbox. The 'O'ring seal will leak red ATF when it fails.
You might get away with pulling the transfer case and shaft just far enough to change the 'O'ring.
bob gauff
bob gauff
aholbro1
08-05-2021 05:02 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
Richard_gib
09-12-2015 07:08 PM
