tranny question
so my auto tranny when i wish to manually shift throughtthegears won't go into 2nd. first, is there a seperate shifter part to tranny? i have an aftermarket warranty and it covers
TRANSMISSION
All internal lubricated
parts in:
• Transmission case
• Torque converter
• Bell housing. so do i have to come out of pocket or do i luck out and get it fixed? i need to get my rear passenger door lock actuator replaced and want to roll it all up. dont want to be at the shop and hear, Well Bill it doesn't cover "that particular part". as always, thanks, Bill
Guest
Posts: n/a
I guess the answer is "it depends" if the problem turns out to be internal to the casing, then you are ok.
But if the problem is a sensor, or switch or the shifter console, or any electrical or computer problem, then they are going to say "Well Bill....."
good luck for now..
luckily the internal parts are expensive.. the rest is cheaper 'cept the computer... but also unlikely.
good luck for now..
If it doesnt do anything in second, are you referring to the shifter not lighting up in second?
If this isthe case it is more likely to be your j-gate being bad. Also the range switch in trans.
I would call ext warr co and ask them if they cover the shifter. Also ask if they cover the power door latches for not working. At least that way you'll know whether to take the lube to the dealer with you.
can't physically put the shifter in 2nd gear. car shifts fine in drive. but it won't go into second gear when i switch it overin the jlocation. sorry for confusion.so to recap. car shifts and drives great,except if i try to shift manually through gears on the jgate then there is no 2nd gear. thanks as always,Bill
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
