Trans. cooler hose leak, and antifreeze leaking at cooler
I am not quite sure of the extent of your problem based on the thread heading.
1. If you are leaking coolant/antifreeze it is a radiator problem.
2. If you are leaking transmission fluid it could be the trans cooler or the power steering cooler.
3. If you leaking both fluids it sounds like something has impacted the systems.
In order to inspect the radiator you will need to remove the underside splash shield.
In order to inspect the trans cooler and the power steering cooler you will have to remove the front bumper assembly.
