transaxle question
Guest
Posts: n/a
RE: transaxle question
Transaxle..Wrong thread, I thought this was a link to some site to do with gays or sex changes or something.
Only joking.
Is this link any help?
http://jagmotorproject.blogspot.com/...sfer-time.html
Only joking.
the reason I was saying this is ,because when I replaced my motor,I had wished I would have changed the fluid on transfer case,now I have to take an engine mount off and use a hand held pump to fill from top.unless I remove the transfer case again.In the autos the fill plug for the auto transmission is located below battery tray.But not the transfer cas.Wish it was as easy as you said.If you call the dealer,they even charge you to remove the transfer case,if you want to change fluids.
just got back from dealer,spoke to head mechanic,he said in order to fill transfer case,you must remove engine mount catalitic converter and drop transfer case.As far as dealership is concerned,they will do it by only dropping the transfer case,since they say there is no space between filler plug and floorpan on car.WHAT A PAIN IN THE A.....
