transfer case bearing
I don't think you will have very much luck around here finding part numbers for a rebuild... The xtype transfer case fails because the casing gets cracked from stress and then it eats itself from the inside. If your bearing already failed, most people would just get a used unit to swap in which has minor cracking and deformation. I'm just worried you're going to spend too much on that bearing. Check car-part.com for used parts in your area
https://www.jaguarforums.com/forum/x...ng-p-ns-60135/
I posted a thread on how I did it. It worked out very well for me. The car is still quiet, and no leaks.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
