Transfer case: LS oil or not
Old 04-17-2016 | 11:42 AM
iownme's Avatar
Default Transfer case: LS oil or not
Time to check that transfer case oil again.. Its been a few years now.
75-140w but i forget.. Limited slip oil or not?
Probably going to use Royal Purple
Old 04-17-2016 | 11:51 AM
DPK's Avatar
DPK
As long as it synthetic and 75w140...nothing else to worry about..I used Royal Purple as well.
Old 04-18-2016 | 09:18 PM
Thermo's Avatar
iownme, if you have the viscous coupling transfer case (ie, the earlier one), then you might find that when making sharp turns, there may be a little bit of wheel hop/jerkiness to the car due to limited allowance for wheel speed differences. But, this is worst case. I have a feeling that you probably won't notice a difference. If you have the later transfer case. you will not notice any difference between LS oil and non-LS oil.
Old 04-19-2016 | 07:17 PM
dennis black's Avatar
I have a 2002 with the vic coupling the best in my opinion transfer case ,from day one I put Redline gear oil and never had a issue, it bullet proof, for me ,in my race car Rx7 that's what I use redline,
In my jag I drive it nice and easy no issues smooth as butter
Old 04-19-2016 | 07:29 PM
DPK's Avatar
DPK
All Red Line products IMO, are far superior than anything out there..
Old 04-20-2016 | 05:12 AM
iownme's Avatar
I'll see if they have it locally
Old 04-20-2016 | 08:11 AM
DPK's Avatar
DPK
I get mine from Amazon..I just bought some for my GMC's Transfer case and rear Differential..Hard to find from a sticks and bricks store
Amazon.com: Red Line 57914 75W-140 Gear Oil - 1 Quart: Automotive Amazon.com: Red Line 57914 75W-140 Gear Oil - 1 Quart: Automotive
Old 04-21-2016 | 07:00 AM
iownme's Avatar
No stores have it here so i got royal purple instead... I'll pre-plan next time and go online
Old 04-21-2016 | 07:59 AM
DPK's Avatar
DPK
No worries..Royal Purple is my second choice, in fact it is what I used in my X-type and I read somewhere that it even has some properties that actually help with healing (if you will) marred or scored surfaces, making them smooth and mirrored like again..
al_roethlisberger
07-16-2024 05:19 PM
Jack Mathews
General Tech Help
05-28-2016 12:34 PM
Ismael S
05-08-2016 01:57 AM
Terry007
04-17-2016 10:51 AM
grantorino62
04-13-2016 10:11 AM
Quick Reply: Transfer case: LS oil or not
