transfer case oil change
Old 06-27-2011, 08:19 PM
Thermo's Avatar
Received 3,922 Likes on 3,222 Posts
disguay, the bigger thing I would be worried about is getting an oil that has the correct oil certifications. If you look in the jaguar manual, it will state the specifications for the gear lube. As I recall it is only something like "AGL" (don't quote me on this). I have used Mobil 1 full synthetic 75W-140 in my car. I go with that because it is easy to find. But, other have gone with Royal Purple and Redline. Both of those are also full synthetic 75W-140 lube. So, look around, see what you can find.
Old 06-28-2011, 09:37 AM
disguay's Avatar
Thanks, just had to make sure that I had the right idea.
Old 07-17-2019, 03:13 PM
Mike Swapp's Avatar
Can I get that pic of the valve you made?
Old 07-17-2019, 03:23 PM
Dell Gailey's Avatar
Old 07-17-2019, 04:05 PM
Thermo's Avatar
Mike, is this what you are talking about?
The valve is a radiator drain valve with a collar on it to accept a tygon tube, then you have a 1/4 to 3/8 NPT reducer and then a 3/8 to 1/2" NPT reducer. You will have to shave the flats as the clearance is close. So, I would say to leave the flats on the 1/4 to 3/8 NPT adapter (like in the pic) and then you can use a thread sealant to lock all 3 parts together.
Old 07-17-2019, 08:03 PM
dennis black's Avatar
i put in redline in my tranfer case when i bought it with 30,000 miles on it ,it now has 198,000 with no problems...its the original transfer case
Old 07-17-2019, 10:51 PM
Did mine after I bought and drove it home to Utah from New Jersey. It was WAY ugly colored (@134,000 miles). See thread w/ pics here (used Royal Purple) =
https://www.jaguarforums.com/forum/x...change-181854/
bamforp
08-14-2024 05:36 PM
Jpav27
US Northeast
12-17-2021 05:40 AM
ZJag
26
09-05-2016 03:33 PM
afterburner1
12-16-2015 12:12 AM
pnwrs2000
09-03-2015 11:55 AM
Quick Reply: transfer case oil change
