transfer case oil change can anyone host web space?
Guest
Posts: n/a
I have a powerpoint presentation with the play by play of doing this oil change. but I cant access my webspace from here.. I will email it to anyone who can host it so we can all check it out here.
The job was fairly trouble free and quite satisfying to do. But the whole thing about lifetime fill just makes me angry.
My car has lots of km on it - 180 000km. As far as I know the transfer case oil has never been changed. There are absolutely no signs of a leak under my car. Every part of the drivetrain is dry as a bone. I certainly did not expect to find what I did inside. When I drained the oil only a half cup of dark thick oil came out.. hardly the 550 ml that are supposed to be there. I cant imagine where the oil went, maybe just kinda evaporated from the heat of the exhaust next to it.
either way, the service was LONG overdue and I refilled and flushed the case with a gear oil and engine flush mixture twice and then a third time with oil only. so in total I drained it 4 times to get it clean inside.. The final fill was with redline 75W140
I dont know how on earth they can say never change the oil.
on top of it all .. the driveline is SOOOOOO Much quiter now that there is oil in the transfer case.
Hi, I'm at a loss..where are you calling the transfercase?..I thought all of that was part of the Jatco transmission..and yes I've been told a dozen times by my dealer, that it is a permanent fluid never to be changed...Which I think is BS anyways.
I'd like to see a copy of that PPT if you can spare it..I can't host it for you, but I sure would like to see what you're talking about..Thanks
edit: I took a look in my JTIS CD and I found the Transfer case...Shows a fill plug but no drain plug..How much did you put in to call full?
Received 9,007 Likes
Guest
Posts: n/a
http://1cbh.spaces.live.com/photos/c...DC839F192!202/the pics are on my msn page.. take a look.. but no script..
Yes I know that you cant drain the last 50ml, but since I flushed it 3 times... I think it will be ok.. certainly better than where it was..
Oh ya.. and JTIS is not clear on the whole thing at all... the fill plug is inaccessible, and they go through a major surgery to drain the fluid... makes no sense at all. they dont even mention the drain plug that is there.
Awesome, awesome, awesome. Thanks bojangles!
If you have a write-up as well in the ppt, send it over to me. I can host it through my school's account (I think I have some 25mb free). Let me know if the file is larger, I may have to clean out some stuff.
Just drop me a pm.
Just drop me a pm.
MC36
US Lower Atlantic
09-01-2015 07:34 PM
