Transfer case oil change write-up now hosted
#81
#82
myjag, what you are experiencing is the difference between the transfer cases in 2004 and up x types. Because the 2003 and below were notorious for having transfer case problems, jaguar decided to change the case around a little bit and reduce the flexing on the transfer case. In doing so, they got rid of the viscous coupling inside of the transfer case which I personally believe is what gave the x type the majority of the awd. Many members on this forum have different opinions as to which transfer case is better and they are all right in their reasoning, but one thing is for sure... The 2004 and up xcases are more reliable, yet they also seem to be more of a rear wheel drive car than an awd car which is what you are experiencing. So to answer your question, your car is fine if the front wheels are not spinning, it just means your transfer case will probably last longer
Also I would like to suggest to do something with the member "kalkoperth." He only has one post, no introduction, his post is faulty, and is advertising in his post which is in a highly viewed thread. Just my thought.
#84
What I'm wondering is how do you know how much to put in? Ok so you drain it out and replace with the amount that drained out, but what if it was low to begin with? How would you know? I have an 04 automatic too and I'm not sure I'd be able to get one of these pipe fittings to fit. I could just squeeze some oil in there but not sure how much or if too much would be bad too.
#85
There is no reason to believe what you get out is the right amount. When I opened mine up, none ran out. So using the "same in as you got out" in my case would mean I put nothing in there and by doing so, changed my xfer case fluid.
I am convinced the 20 inch lift is the right way to install the correct amount. Jack up the left side of the car until the bottom of the body work that is in line with the front edge of the front door is 20 inches high. Take out the transfer case plug and add fluid until it runs back out. Then replace the plug. All the flushing and fittings and valves seem an extra complication to me, and I think may be impossible on the automatic transmission. There is just no room for it.
I did mine during an engine oil change. Then the next time I changed the engine oil I jacked up the right side of the car 20 inches to drain xfer case fluid out. Then lowered that side back down and raised the left side and added fresh fluid to the xfer case as above. The first time I did I measured the fluid that went until it was full and it was about 400 ml. The procedure says about 200 ml remain in the xfer case when you drain. So that would be about 600 ml total after drain and fill.
And to answer your question, yes, too much in there would be way bad.
#86
Ok thank. Your way sounds easier than trying to find all those parts at a hardware store. I'm confused though. So first you lift up one side to drain it out, then you lift up the other side and fill it up till it pours out... while it's still lifted up in the air or when it's level? I'm just wondering do you lift the opposite side up to fill it till it starts to overflow? Thanks.
#87
Yeah, Zach not sure where you live but assuming you're a US Jag owner and your steering is on the left side as you sit in the car....
Jack up the passenger side to drain the transfer case. High as you can safely get it. 20+ inches is good. Chances are if you get any fluid out, it will be nasty looking. In my case, I got none out. So I added some until I got it come out. I think I put 50 ml in there before any ran out, so there was no more than 150 ml in there of the 600ml that I should have had. Pretty low. And that was with no leaks, then or now. It was just gone, evaporated.
Now, you can just leave the plug out for now. No worries. All you're going to get out of it is now in your drain pan. Lower the car back down. Move your jack and all over to the driver side. Jack it up until the bottom of the car just behind the front wheel is 20 or so inches off the floor. You don't have to shoot that 20 inches in with a laser and transit. There are other variables playing here. I'd say, not 19, not 21, but 20-ish inches. Not that critical. The first time I did it, I wanted to measure it so I put 500 ml in a measuring cup and pumped it out of the cup and up into the transfer case with a fluid pump I got at the auto parts store. I pumped it until it ran back out of the hole. I don't remember now but I got like 400, 450 ml or so in there. I put the plug back in. It does not have to be gorilla tight. Just snuggly. I'd betcha you can crack that case open if you get the plug too tight. Lower the car last, after you are all buttoned up. You're done. If you didn't like the ugly look of any fluid you got out during the drain, drain and fill again the next time you change engine oil.
I used synthetic 75W-140. Royal Purple.
If this was worth anything to you, be sure to click that Thanks button-->
#89
Well I suppose you could do that to make sure that all the old fluid drained out, but it kind of seems a waste. Just remove the drain plug with the car level on a lift and nearly all the fluid will drain out.
Them, after waiting a bit, place the blocks under the left side of the car and lower it down so that the left side is 20" higher than the right (i.e.., the drain hole is now facing upwards). Then add fluid until it starts running out. Replace the plug, raise the car, remove the blocks, lower the car and you're done.
Easy peasy
Jaguar: Grace, Pace, and Space - Sir William Lyons
Easy peasy
#90
[QUOTE=pab;845159Just remove the drain plug with the car level on a lift and nearly all the fluid will drain out.
Easy peasy
[/QUOTE]
If only it was so easy peasy! If the transfer box is drained through the so called drainplug, there will be 250 mls of fluid left in the box. I know this to be so as I have fitted an additional drain point at the lowest point in my t'box and have checked it very carefully!
Now that might count as 'nearly all out', for some but it's nearly 50% to me and if not removed severely reduces the effect of what should, for best results, be a complete oil change.
Easy peasy
[/QUOTE]
#91
Got any pictures of that?...I think that is cool and if you could also explain how you went about installing that drain, as it could benefit many X-type owners here..
#92
DPK (11-02-2013)
#93
#95
Yepper, you mean Transfer Case..and in most cases, people are finding their TC either almost empty or about 300ml left..So the sooner one get's to it and refill it with some decent Synthetic gear lube (I used Royal Purple), the TC usually ends up failing sooner than expected.
#97
#98
Good news, I was able to add some fluid to the transfer case. Looked like it was low because none leaked out. Filled it up and took it for a spin and it shifts and drives a lot smoother. Seems like it revs easier now. Glad I checked it out. I would have been rolling dry for a while.
Just a note:...so many worry about getting the exact amount in..It really is not that critical..too much is better than not enough..If you drain all you can from the drain hole..there is supposedly about 250 ml left....if you tip the car as far as you can from the left side and fill, you may get in about 500ml plus what was already in there...this is what I did and never had a problem,..But by the time you wrestle getting the plug back in you'll lose a couple ml anyway... it's not like the crankcase of an engine, where over filling can damage the engine...So don't sweat it if you think you over filled a little..some have a vent at the top and the excess will ooze out there sometimes...I never had any excess leakage.
#99
Alright thanks for the advice. I did do the tilt method, but I used the spare jack because that is all I had around at the time. It did help with filling though, I was able to get more in there. I should probably get a proper jack at some point. In a few months I was going to drain and fill it again like you said. Noticed the magnetic plug had some silver metal goo stuck to it. Cleaned that all off real well. I think I checked it just in time. Drives so much smoother now and feels better knowing there is some fresh oil in there. Next job on the list is the transmission fluid.
#100
