Transfer case replacement
Just bought a 05 x type with a bad transfer case already removed by the previous owner.. have since bought a replacement and ready to reibstall... QUESTION: on a scale of 1 to 5 with 5 being the best I consider myself as having a 2.5 or 3.0 when it comes to mechanical skills.... I am thinking of trying yo put in the transfer case myself... do you think I will be in over my head??
THANKS
THANKS
https://www.jaguarforums.com/forum/x...ere-how-12996/
https://www.jaguarforums.com/forum/x...er-case-93353/
Post #8 =
https://www.jaguarforums.com/forum/x...rchange-64151/
Many more if you do a search........
Post #8 =
Here are some more useful links, although they do suffer from the photobucket ban on free photo sharing. I believe there are workarounds? Anyone know?
How to replace a Transfer Box
Transfer Box removal, rebuild and replacement
Sorry, but to be brutal, noting from your OP
get another transfer box!!
Replacing the seal that only might have been damaged if that shaft was removed with its wire clip in place at the splined end, is a major engineering job requiring the t'box to be stripped and rebuilt. Not one for the faint hearted!!
You should be able to get a partial view of the seals inside the box, looking in the left hand side to see if there's any obvious damage.
Good luck!
Good luck!
motorcarman (03-18-2018)
Muamin
02-10-2016 08:36 AM
Maxmaxemus
04-22-2013 09:18 PM
