Transmission Kick Down Switch
Does anyone know where i can get one and where it goes, a while back my check engine light came on and the after looking up the code, it pointed to a transmission kickdown switch. The light has since gone away but sometimes when driving on the highway when i try to pass someone and overdrive kicks in it hesitates and jumps to get into gear, anyone else experienced this problem before?
RE: Transmission Kick Down Switch
It's all fly by wire stuff....so there is no kick down switch per-say....
You either have a solenoid problem (in the tranny) or a speed sensor problem (in the tranny and wheel bearings)
or throttle position/accelerator problem....would help if you post code, i can look it up
aholbro1
08-05-2021 05:02 AM
