Transmission question.
Standing start, use the same throttle pressure and look when it shifts. Do the same after you press the S and see if it is lower or higher (since if the light is burnt out you won't know whether you are in sport mode or not.)
If nothing changes likely the switch is pooched. But I don't think it has any effect on the transmission, it's electrical.
