Trouble with doorlock
Old 07-20-2007 | 11:43 PM
Zack's Avatar
Default Trouble with doorlock
Hello everyone, I purchased a 2002 3.0 X-Type Sport Edition 6 months ago. Up till now, it's been pretty troublefree, but a couple of days ago, I started having trouble locking the car with my keyfob. I can't get the keyfob to lock tghe door consistently and when I force it using the key, it locks, but I get 2 beeps. Does anyone have any ideas what could be wrong? Just for refference, i've opened and closed all the door, trunk, and hood. What else can I be missing?
Thank you all in advance.
Zack
Old 07-22-2007 | 09:17 PM
aquill1's Avatar
Default RE: Trouble with doorlock
Not sure there Zack haven't heard of that problem before...as you said though you checked that all doors and hood and trunk are closed....does a light come on inside the car when you have it running and all doors are shut?
Old 07-23-2007 | 01:35 AM
Striker27's Avatar
I had the same wacky problem. When you turn your car off do you hear chimes or anything???
Old 07-23-2007 | 10:49 AM
aquill1's Avatar
Come on guys help a brother out here....
Old 07-23-2007 | 11:53 AM
SpartanX's Avatar
Turn the car on. See if the message center says "Boot Open/Trunk Open". If so, open the trunk, and close it again. Press the button before you close it so the lock can engage.
As for the key fob problem, take it apart and clean it. Worked for me, as I had some sticky stuff on my buttons which was preventing it from working properly.
Old 07-23-2007 | 11:57 AM
93xj6's Avatar
Is it possible that the battery is dieing?
Old 07-23-2007 | 12:36 PM
SpartanX's Avatar
ORIGINAL: Striker27
If you hear chimes when the key is out, the ignition switch door (that little door that covers the key hole) isn't shut. To solve this problem, put the key in just a hair, and turn the ignition toward you just a hair. That should close the hole.
Old 07-23-2007 | 01:35 PM
Striker27's Avatar
Or when you hear the chimes just lubricate the lock mechanism.
Old 07-23-2007 | 04:05 PM
aquill1's Avatar
ORIGINAL: SpartanX
Same thing I was asking him but he hasn't responded yet...
Old 07-23-2007 | 05:33 PM
jag_genius's Avatar
there is one thing that happens.. specially after body shop has had it.. the switch under the hood which tells the car the hood is closed sometimes the pad where the switch touches falls off,, so when you close the hood the switch doesn't fully close causing the double beep..it's a sticky pad.. is the pad there? its' black about a inch in diameter.. near coolant resevoir
Old 07-23-2007 | 07:49 PM
aquill1's Avatar
Few days ago since he posted maybe he forgot or it worked itself out! I'm going with the latter as that happens with my problems....they all seem to sometimes work themselves out!
Old 07-23-2007 | 07:56 PM
Yeah I got that with the door handle scenario.......If you remember, sometimes it opened up ok and sometimes it didn't.........Everything seems fine so far
Its decided to work again.....weirdddddd
Jim
Old 07-23-2007 | 08:53 PM
aquill1's Avatar
Yeah knock on wood ( which I am doing right now) mine has been working almost without a hint of me having these problems!
Old 07-25-2007 | 04:04 PM
Can't wait for the winter, that seems to be when all these little quirks / problems etc show up[&:]
Jim
Old 07-25-2007 | 04:38 PM
aquill1's Avatar
Think so...mine seem to just come and go when I use the car more or don't want them to pop up!
Old 07-26-2007 | 11:22 PM
Zack's Avatar
Sorry everyone for the late resonse, but i've had a heck of a week at work (I work in the IT Dept of a construction company). Anyway, here's what i've tried/verified:
1) The message center doesn't say anything about any doors/trunk/hood being open.
2) The 2 beeps I heard the other day when I forced the car to lock are no longer around. I'm not sure what the deal was that day, but whatever it was, the behavior no longer exists.
3) The keyfob continues to unlock the car without trouble, but I can't seem to lock it using the keyfob.
What i'm going to try now is replacing the battery. Is there anything I need to worry about when changing the battery (loke losing the relationship between the keyfob & the car)? I'll report back after I try this.
Thank you all for your help.
Zack
Old 07-27-2007 | 02:19 AM
Striker27's Avatar
I lubricated the lock cylinder and the damn chimes went away, plusmy key fob works now!!!
THANX GUYS!!!!
Old 07-27-2007 | 08:57 AM
aquill1's Avatar
Just keep in mind that these cars do many funky things! They come and they go...hey zack what year is your car? Mine had a recall on the keyfob and you could take it to a jag dealer and have them look at it...they replaced my key fob and the batteries in my other one...good luck...
Old 07-28-2007 | 03:18 AM
04Xtype's Avatar
my key stopped working a couple times. i had it replaced about 6months after getting the car, needed to have it fixed again about a year later, and then about half a year ago got the recall thing, i dunno what it was that they did, but it looks and does the same thing as before. hopefully they dont break now
Old 07-28-2007 | 09:33 AM
Cadillac's Avatar
I have no idea what's going wrong with the keyfobs .I don't think I have heard some problems associated with the keyfobs for other Jaguar models
Quick Reply: Trouble with doorlock
