Trying to Keep It Running
A few months ago I bought a 2003 X-Type AWD with about 140,000 miles on it. The car looked great, seemed to run well, was fairly inexpensive, and I had always wanted one. Well, since then it's been one thing after another.
Last week I had a transmission sensor installed after the car kept thinking it was in "drive" and would not start. Over $600 later the car worked. A few days later the infamous "Gearbox Fault" and "Cruise Control Not Available" messages came back. I took it back to the mechanic, who happens to specialize in Jaguars, cleared all the codes and told me to let him know what happens. The messages came back. He said that I might have a "tranny problem."
The transmission seems like it slips just a little bit. When I'm coming to a stop, I can feel it shifting down as I approach a stop. I can actually hear a soft "clunk" - it's barely audible but I know each sound my car makes.
Before I spend any more money and have someone look at the "tranny", any suggestions? I'm seriously selling this car......
Thanks!
Thanks!
Looking down in the engine compartment right next to the side of the battery box you should be able to see a rubber plug. That is the fill hole for the transmission. You should be able to reach down with pliers and remove the the plug.
Make sure you follow the level checking provedure before just adding more fluid. Over fill is just as bad as under fill.
https://www.jaguarforums.com/forum/x...w-pics-183620/
Second page has the repair manual procedure on the only and correct method to check a Jaguar X type transmission fluid. PITA!!
Just my personal viewpoint, but I wouldn't let a Jiffy Lube with a city block of my car. Even so called expert transmission shops gave mistakenly spun the wrong plug out of the rear of the transmission to check the fluid level. When they do that, they screw the reverse band (held by the plug/screw) & you end up with no reverse and limited movement forward. Taking the transmission out to repair the muck up is a mess.
So, let me see if I got this right. I CAN check the transmission fluid from the right side of the engine via the plug? However, I still don't know how I'll know how much fluid I will need. I'm obviously trying to avoid going to a shop and paying several hundred dollars to do this. If possible I'd like to check the fluid myself. Many thanks!
perhaps a fluid swap would be in order.
every 20K ( on all my cars ) i drain the fluid in the pan and refill. Keeps the fluid fresh
for the xtype i use the castrol multi vehicle import, and if i remember correctly the drain is 3.5Qt. but if your fluid level is low or even high you may be best bet to just drain and refill.
the process is actually super easy on the xtype . drain plug on bottom of trans , and get a very small funnel and a tube . works no problem.
i keep the exact fluid capacity written in my notebook in my garage so cant speak to the exact amount , the 3.5qt stated above is a best guess from memory.
