I've recently bought a 2006 X-Type 2.2L D (M) and found that the Turbo Actuator needs replacing. Does any-one have any ideas where I could get a replacement - new or re-conditioned?? Thank you
Could just be a case of getting somebody with a soldering iron to touch up some of the connections. Looks like it's a common issue, and it had already been done to my car when I bought it. You could just pick up a cheap soldering iron and give it a go yourself if they seem loose. Or some guy in a garage could probably do it in about 5 minutes. Assuming this is the problem.
But if one of the components is shot then you could probably pick one up on eBay for £20-60
