Turn Signal Lights Not Working
All my turn signal lights. this happenned after replacing my dead battery with anew one. The failure could have been caused by jump starting when trying to start car.
Does any one know the fuse number for the turn signals (or relay number if there is any) I tried to look for the fuse location in the Owners handbook but it is not there.
Received 3,910 Likes
mmolaik, the turn signals are powered from the GEM module. So, as long as your power windows are still working, you know your GEM module is still getting power. You would need to verify that the turn signal is still in good working order. After that, it doesn't leave much else that it can be. If you need more info, let me know and I will see what I can do to give you specific wires to check with a multimeter.
mmolaik (11-28-2010)
Mmolaik, what you will need to do is to remove the plastic trim from around the steering column. This will expose the turn signal switch. Now, remove the plug from the turn signal switch. Locate the blue/green striped wire (there are two of them, either one will work) and the black wire. What I want you to do is using a small piece of wire, I want you to use the piece of wire to short these two points together (make sure to have the ignition key in the RUN position). This should cause one of your turn signals to work. If it don't, then that confirms a bad GEM module, replace the GEM module. If the lights work, then you have a bad turn signal switch.
I hope this helps you out. If you think you have a bad GEM module, verify that the black wire is shorted to ground by doing a resistance check between the black wire and the body of the car (any bare metal surface). It should be under 5 ohms. If you are getting something over 5 ohms, then your problem is this black wire is not connected properly. You need to fix this black wire.
mmolaik (12-05-2010)
I managed. I followed your instructions and managed to trace the fault to burnt insulation on the headlamp wires which were creating a shortcircuit and blowing up the GEM fuse(Fuse F25). I replaced the wires, replaced the fuse and everything worked fine.
Now I need to replace the battery positive cable which is getting hot.
EFlavio
06-05-2013 04:22 AM
