Turn Signals Relay and Oil Dipstick
Received 3,932 Likes
cje, there is no tranny dip stick in the car. The red handle that you found right in the front of the engine (to the left side) is for the motor oil. The only way you know that you have the proper fluid level in the tranny is to go through a procedure and remove a fill plug which should have the fluid level just below the edge of the plug.
As for the turn signal relay, there isn't one in the car. The relay action is controlled by the GEM module. What are you trying to figure out, may be I can help you get to a resolution.
