'tweet' from engine compartment when setting off ...
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Recently acquired a 2005 X-Type LS with the 2.0l diesel engine.
The test drive showed no anomalies, but once back home, after a hundred miles or so fast drive back on the motorway, I now notice a short but loud tweeting sound from the engine compartment when I either pull away from standing in first gear OR switch the engine off.... It lasts for only a second or so, and isn't heard at all during normal motion. It also only occurs once the engine is warm - from a cold start I hear nothing.
The seller did mention he'd changed the auxiliary drive belt recently. Could it be that it's stretched slightly during use and now needs re-tightening? What other issues could generate these symptoms? TIA.
There isn't any real adjustment for the accessory drive belt or the water pump drive belt. Each has a tensioner that provides a pre-engineered amount of tension against the belt.
If it always chirps at shut down you can easily remove the water pump belt and start up and shut down a few times to determine if it is the accessory drive belt or the water pump belt making your chirp.
Then you can try a new belt or possibly have to replace the tensioner.
twocups (04-27-2017)
Thanks @avern1.... I had the car in a local garage today. They confirmed the auxiliary belt was new .... but couldn't (or wouldn't) pinpoint any further :-(
As it happens, I do hear the tweet at shutdown also (forgot to mention that) - so the water pump belt or the aux drive and water pump belt tensioners are the next ports of call then ...?
twocups (05-03-2017)
