u0001 remove TCM (on gearbox) and gear selector cable
So, I previously had the turbo/gearbox/glowplug light on, and sorted it with the Mr Muscle method, but I'm still getting an engine light, just without the glowplug light.
After doing a scan I get U0001 High CANBUS communication with TCM error.
I checked the connections on the TCM connector, and on the block connector, and they seem good. There was some, what I thought, was water in the connection, but I'm thinking it must have been electrical grease. But I cleaned all the connections anyway. No change.
Next step was to check the TCM itself. I went at it yesterday, kind of late, and wasn't sure how to get the gear selector cable off (photo below). Anybody know? Push down on the top? Or just force it off? Or can I Just pull out the TCM with it still attached?
I had the bolts off the TCM but it was still kind of stuck so I didn't force it. After checking a photo of one on eBay later it looks like there's some kind of connection underneath, going into the gearbox I assume.
I'm guessing this might be where the problem is because the problem was intermittent before, but after messing with the TCM the MIL light is permanently on the dash now and won't clear at all. Before it would just randomly come on after an hour or a day.
Also kind of strange was that a connector on the cooling fan module was disconnected, seems to be 2 of them right beside each other. No idea if it's a related issue or not. Maybe depending on if they're on the same CAN network. Must check out a wiring diagram.
But yes, my main question is about disconnecting the gear selector cable from the TCM. How do I do it? The workshop manual just seems to gloss over it, and I don't want to screw it up!
And of course any other photos, links, suggestions, diagrams, and general wisdom would be nice, if anybody wants to chip in.
Same issue with my Hyundai Elantra 2012
So, I’m kinda having the same issue with my car here except that I still did not try to disconnect or clean/repair anything. I was hoping that you found the exact cause and fix to your problem here. It would really help me if you do have more information about this issue.
please feel free to reach out to me via email if you can help, I’d really appreciate it.
my email: km124211@gmail.com
In my case the check engine light is related to the Readiness Monitor not completing the emissions check (P1000 code) and it's probably related to the EGR system, but communication error seems to just be a small random issue that doesn't affect anything. I can make the coms error happen by moving from P to D and I get a few errors as the shift moves, but it seems like a non-issue, more like the ECU doesn't quite know what position the shifter is in.
But I can't get rid of the pesky engine light because there are no other faults and the car runs just fine! I mean I can clear the fault, but it comes back after 3 restarts.
And when I go for my NCT (Irish MOT) I just clear the faults before I hand over the car and it always passes, no problem, and then the check engine light comes on again on the way home..
johnnyo
01-20-2014 12:34 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
