Unlock car door without keys
Received 3,887 Likes
Try it and let me know how it works for you. May I recommend using a basket ball as you will probably have better luck.
Using what they are saying in that the tennis ball is pressurizing the car door to push the lock mechanism up, you would have to apply around say 2 pounds of force to lift the lock mechanism (most take more than that, but I am going to give this the benefit of the doubt). Since the area of the lock is around 0.5 square inches, that means that you have to apply 4 psi of air to the interior of the door to push up with 2 pounds of force (4 psi x 0.5 in2 = 2 lbf). Making the assumption that the door is air tight (if you have looked at the inside of a door, you will see that this is completely wrong, but I am giving it the best chance that it has), the interior volume of a door is around 4 cubic feet (or roughly 7,000 cubic inches). So, you would need to raise the pressure inside the car door from 14.7 psia (normal atmospheric pressure, as measured in absolute pressure) up to a minimum of 18.7 psia. This would take something with a 1900 cubic inch volume (or roughly 12.5" x 12.5" x 12.5", or something bigger than a basketball). This is best case. Keep in mind that you are having to push this though that little key hole in a very short period of time to minimize air losses. in short, the pressure needed to do this is far more than what you can generate.
If you make the assumption that the air is somehow causing the tumbler to move and magically hit the right points to allow things to move, I could possibly give you that. But, this is where that falls flat. This is assuming that the air pressure is being applied unevenly and can somehow move all the internal parts of a door lock to the correct place and then at that same moment, cause the internals to twist in the correct direction to flip the lock mechanism. Good luck on lining up the stars on that one.
Just saying............
DUNKS, granted, I have a much better way of opening the door. Unfortunately my way can only be done one time. Something about a pound of C4 wrapped neatly around the edge of the door. You can get away with only about 8 ounces, but then you have to use a shaped charge to get the needed effect. Gotta love working with the security guys. The things you learn that makes life much more interesting.
Dell, ironically, I am not an engineer. Just a "lowly tech" that has had to school some engineers in my day. My job requires me to know a bit about everything. Mix in some general curiosity about things and a willingness to learn, the world is a fruit basket waiting to be picked clean. What can I say, I love to learn about things and add it in with the other stuff I have learned to really find some interesting ways to do things. Toss in some general curiosity and oh lord can you have some fun.
DUNKS, you are talking to the guy that has climbed inside of a nuclear ballistic missile and also had to learn how they make nuclear bombs. The vests are too small of a boom for me. If I yell duck, don't be asking "where"? He he he he he he. Ever seen a water gun that uses 3000 psi air to shoot the water? I have. All you see is a little silver dot flying at you (right before it hits you and knocks you off your feet). Oh the days of being on the submarine.
