Unusual Problem with X-type
I have a 2003 x-type, 2.5 and I am experiencing an odd problem. At highway speeds my left front brake will without provocation start to grab and release, at least that is what it feels like. I will get a mild vibration (wobble) and it will build until the steering wheel shake. If I apply the brakes while this is happening the car has a severe shudder. If I continue to drive the problem resolves itself and the car rides smooth and quiet. I have replaced the caliper, caliper guide pins, rotor and pads to no avail. Could the ABS sensor have anything to do with this? Can not think of anything else to do. Help would be appreciated.
If you have some advice please email me at
vicmoschella@netscape.net
Received 2,643 Likes
Received 3,906 Likes
I think DPK meant to say that the DSC (not DTC) was kicking in, meaning that the car thinks the wheel is slipping and therefore is applying the brakes to slow the wheel down. If your car is equipped with DSC (button on the center console that shows a car skidding back and forth), press the button once to turn off the DSC and see if the problem continues. If the problem continues or your car is not equipped with DSC, then you are most likely looking at an ABS issue or a caliper that is starting to go bad.
DPK (04-06-2016)
Received 2,263 Likes
PbJag
19
08-31-2018 01:07 AM
