Upper Radiator hose, thermostat housing
Old 08-11-2013 | 08:46 PM
akubeta's Avatar
Default Upper Radiator hose, thermostat housing
I am in the middle of replacing my Upper Radiator hose (X-type 2002), when I got stuck trying to remove the 13mm nut for the thermostat housing, it is in an awkward position. and I can't seem to get it out. Are there any tricks or tips on removing it?
Old 08-11-2013 | 11:31 PM
cujet's Avatar
I just changed mine. Ended up using a combination of tools to do the job.
The end result was that a 3 inch extension and a thin wall socket was needed for the one that's impossible to touch.
Once loose, I used just the extension and socket between my fingers to unscrew it.
Wahooesprit
12-23-2019 03:01 PM
Tipptone
09-16-2015 08:39 AM
1964Daimler
09-09-2015 12:28 PM
Quick Reply: Upper Radiator hose, thermostat housing
