URGENT: Debris in air inlet tube to Turbo
I have a X-Type 2.2D (2009)
I regularly clean the turbo using Glyns Can Spray Turbo cleaner, this can of cleaner comes with a small, flexible plastic tube to direct the spray.
How I do this is by unscrewing the air filter rectangular box, lifting the lid, remove the air filer. Start the engine and leave on idle. Lift the air filter box lid up with the air pipe to the turbo still connected and spray at small blasts until the can is empty.
I had the tiny pipe from the can connected to the nozzle and the damned thing came off and I cannot find it.
Clearly it was sucked into the large tube/hose going to the turbo.
I needed the car so had to take the risk and drive it. So far, after 100 miles nothing has gone wrong.
So would this tiny tube just been sucked into the turbo and disintegrate or maybe just sitting inside the large tube or is there a filter inside that tube stopping it getting to the turbo or is this a ticking time bomb?
Any thoughts please would be really appreciated.
How to clean turbo?
https://www.jaguarforums.com/forum/x...-codes-133428/
https://www.honestjohn.co.uk/forum/p...x.htm?t=107778
https://www.pistonheads.com/gassing/...&f=85&t=870059
X Type 2.0d manual estate (06) - Turbo problems / Vibration - Jaguar Owners Lounge - Jaguar Owners Club
Etc., etc.......
Etc., etc.......
I don't think it would make the first turn beyond the turbo, and it is for certain that the heat would have melted the thing. If it made it into the cylinder, I'm pretty sure the combustion pressure would pretty much vaporize the tube, and it is pretty much made of the same material as the diesel fuel, anyway.
Best guess: It is already gone, cooked off and passed out through the exhaust!
