Vacuum Leak
I've had my '02 X-type for exactly 4 weeks now... and the check engine light has come on again. The first time it happened less than 24hrs after driving it off the lot. One of the error codes came up as a vacuum leak... that can mean a lot of things. The used car dealership where I bought it took it to a Jag dealer and had it fixed. Turns out the bank 2 catalytic converter was blown. Now the check engine light is on again, and once again the error code talks about vacuum leak... now I am wondering...
1. is it possible the cause of this vacuum leak is also why the catalitic converter was blown and by replacing the catalitic converter they took away a result of the problem but not the cause?
2. other than the gas cap, what could cause this error?
Any ideas?
Thanks!
K.
Any ideas?
Thanks!
K.
Guest
Posts: n/a
not sure what code is vacuum leak.. best way to communicate here is with the acutal OBD code.
Assuming that the fault is typical, it might be the IMT port o-rings or the PCV hose, or the brake booster check valve. they all cause lean running (vacuum) codes.
nothing to be upset about, easy cheap fixes.
Are you sure they changed the catalytic converter? have you looked under the car and seen the shiny new one? Normally lean running will not quickly kill a cat, rich running is much worse for the cats..
If you get the actual code for the check engine light, we can eliminate the gas cap vs engine air vacuum leaks...
Took my baby in at the local Jag dealer... Waiting to hear what they find... if that's an evap code, that's the second time in one month that I get an evap error code... I think I will call the dealer and remind him of that...
Unfortunately, I don't have the time/equipment/knowledge/room for a lot of car tinkering... and I trust the Jag dealer more than I trust myself when it comes to fixing things on my car.
I'll keep you posted on what they find...
clubairth1
29
05-10-2024 12:57 PM
OkieTim
09-08-2015 04:48 PM
