Vacuum Tube
Anyone know the Jaguar official name for the the vacuum tube so I can look it up online? Dealer noted on my last visit that it's leaking from intake to fuel pressure regulator and would need changing eventually. I'm obviously gonna do it myself, but I can't find the part without the official name.
Ok, this is a complete shot in the dark, but I would go check your brake booster hose. It looks like this: http://www.captainjaguarscathouse.co...s/C2S17522.JPG
The plastic part tends to get broken down and will start to leak. Mine was so far worn down that if started throwing P0171 and P0174 codes. I fixed it by sealing the old plastic valve with epoxy and it has held up great.
Hopefully that's your problem because that's where most vacuum leaks come from.
Thanks for the tip. I'll take a look at it this weekend. Yeah, the dealer said it's a matter of time before I start getting some codes popping up.
Pretty sure this is what your looking for...
https://www.jaguarforums.com/forum/x...ication-37354/
I posted part numbers about halfway down.
