Warning lights on and limp home mode on X Type SE 2.2 D 2007
Can anyone help diagnose this issue. The car had been driving perfectly but then suddenly the engine malfunction, Brake, ABS, charger and glow plugs warning lights come on. The air con switches off and a message is displayed saying cruise control not available. The car then goes in to limp home mode. None of the dials work (speedometer or rmp) they just sit at zero. The display for the miles on the car also turns off.
if you run the car with ignition on without putting it into gear and trying to move it this doesn't happen. Within a few seconds of trying to move the car all of the above occurs. The passenger airbag warning light also comes on.
the car has been regularity serviced every year.
any idea what might be causing this... I think it might be an electrical fault?
thanks!
thanks!
Welcome to the forum Lucinda,
I've moved your question from Diesel variants - All models to X-Type forum. Even though a minority of members have diesels, it should get more attention here.
