Washer fluid doesn't come out
Check and make sure the hoses are in good shape. I've had to replace mine recently. Also make sure the nozzles are not clogged with debris. I had to clear one on mine. You can use a sewing needle.
Latest problem on mine is the pump won't run but it's intermittent. Since yours is weak not dead I guess we can assume your pump is running.
I had the same problem, There's a rubber filter where the pump attaches to the reservoir bottle which was blocked. Easy to get to behind the wheel arch lining. Here's an article from the UK Jag forum with pictures describing it.
blocked washer bottle
Found this guy on ebay he sells the pair of nozzles for the hood for 30 bucks witree shipping.
02 03 04 05 06 07 Jaguar x Type Window Windshield Washer Nozzle Pair 2pcs WP05 | eBay
Xerxes' Jag (11-02-2013)
aholbro1
08-05-2021 06:02 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 12:56 PM
mikimogo
09-14-2015 09:34 PM
al_roethlisberger
09-11-2015 11:04 PM
