Water pump?
I am having a problem and not sure if it's my water pump. Thoughts?
The car runs fine. It does not overheat. However, it leaks antifreeze when running. I can leave it parked for a week and not one drip on the ground. If I start it up, I notice antifreeze on the ground after 15 mins. Does it sound like the water pump is leaking? I would assume it's that, but the car is not overheating at all and the temperature holds steady. That's why I'm questioning it. Also, wouldn't the water pump leak all the time, not just when running?
Thanks!
Thanks!
pdfisherman (01-02-2015)
Received 3,908 Likes
FYI I had a similar scenario. Try this, with the engine at operating temperature open the hood and have someone rev the engine about 3,000 and watch around between the radiator and the fan, that long pipe is plastic there has a tendency to crack and open up at high throttle and never leak any other time. Also the reservoir tank pipe cracks and leaks at high rpm.
Thermo is right, you have to get a very bright flash light, run the engine to the operated temp. look under engine to see where is coolant drip down, the try to trace to where is coolant came out; Because if water pump is leak it will leaked right after engine is running, but if the hoses or gasket leak ( small leak) it will happen when engine is hot and pressure build up, some time it hard to detect because the leak at one point but coolant sprayed to the other point.
Ozzy_UK
45
02-19-2019 02:05 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
