What to do with left foot?
Old 12-14-2008, 06:27 PM
christo's Avatar
Default RE: What to do with left foot?
Do some push ups - lol!
I have close to an hour commute and my foot just sits there. Eventually my heel goes numb, but it comes nback real quick. I like sitting further back than I have to, just a driving style I guess. Most of the time I am driving with the right hand leaning towards the drivers side window and then after a while I go the other way, but usually driving with one hand holding the center of the wheel.
Old 12-15-2008, 07:30 AM
The Chris X's Avatar
ORIGINAL: jvegas
thanks for the picture... it was the X-Type we wanted to see. Do you have any of the X-Type?
no pic - I didn't take one because unless you have an extra piece from a wood dash kit, you wouldn't be able to do it the same anyway.
visualize a thin piece of wood veneer, roughly the same size and shape as that pedal in the pic, but solid, placed in the same spot, with a lighter color carpet. I know you can do it!
Old 12-15-2008, 07:39 AM
christo's Avatar
Ok, here it is, I am sitting too far back, I need to rase the foot rest, maybe the size of a 2x4 block - is there anything out there that will look pretty?
Old 12-15-2008, 10:36 AM
maybe just get a pair of Doc Martens with a super thick sole! Like platform shoes.
Old 04-04-2015, 12:10 PM
saltyolddog's Avatar
Default A Solution - if a little late in the day.
Only acquired the car last October. It's still done less than 50,000 miles and is in very good order.
Like others here, I was dismayed to find nowhere sensible for my left foot when not operating the clutch. After a 300 mile drive, I was left with a swollen ankle, so ended up searching for a footrest.
Racing Green Jaguar will provide you with one but charge GBP 150.00 for the privilege. On the other hand, you could buy part number A111A0103F from Bell & Colvill for just over GBP 21.00 including UK postage. It's a Lotus Elise (I think) part. Picture attached. On my RHD X-type, it's fairly simple to bolt it to the carpet-covered (substantial) plastic trim panel on the gearbox tunnel. The panel is detachable, so you can drill bolt holes and fix the footrest off the car.
With an assistant, position the part where you would like it and mark the 3 mounting positions. As my X-type has dark grey carpet, we used Tip-X correcting fluid to mark our drilling points. Take off the trim panel. Mostly, it's fixed with clip-on fasteners but there is at least one self tapping screw hiding behind the drivers seat cushion. It's best to fit your fixing bolts with their heads on the inside to avoid problems with re-fitting the trim panel and you might need to slightly adjust the footrest angle to avoid the front fixing point interfering with one of the panel supports. Replace the trim panel: Job done.
The following 2 users liked this post by saltyolddog:
Paora (05-05-2019), wa3ra (04-04-2015)
Old 04-05-2015, 07:28 PM
henry k's Avatar
My ( UK) 2007 X type has what looks like rest for a left foot.
It is on the passenger side ( by the hood release) .
I can only assume it is like a few other " features " part of Left Hand design that we Brits have to cope with.
Old 04-06-2015, 12:15 AM
FollowMe's Avatar
Originally Posted by christo
I was wondering why there isn't a foot rest for your left foot in an automatic x-type. I know the car can have a manual but does this mean tht they over looked comfort for the automatic? Can I get one installed, my foot falls asleep...
This is the craziest thing iv ever heard.
PlatinumJag
20
10-02-2020 02:23 PM
neruda
10-18-2015 01:19 PM
Pluckie
10-03-2015 07:57 AM
shootingbrake
09-23-2015 10:54 AM
Ekki
09-21-2015 12:09 PM
Quick Reply: What to do with left foot?
