What to do with TCM?
Charm, have a friend with an X-Type? If so, see if you can put your computer into his car and see if the problems you are experiencing show up there. Or, pull the computer out of his car and put it into yours. Kinda a 6 of one, half a dozen of another. If you are not that lucky, then I would start looking to see what you can find in the way of wrecking yard parts.
If you do some looking on the forums here, there was a company that was talked about on here that will take your TCM and rebuild it, restoring it to "like new" condition. Not sure what they would charge you for something like a TCM, but I am sure it will be more than getting a used TCM.
Your call, but that is the options as I see them.
Should be fine, then if it is zap strap it so the wire loop up instead of down onto something high up on the firewall so the moisture you're getting will drop down off the wires before entering the TCM.
I took my x type to a Tranny shop where they did a quick check up,
they hooked my car up to something and looked for and tranny error codes and what not but nothing showed up. Since nothing showed up they decided to take my car out for a drive, they said the car does drive funny with the RPM going up but not accelerating, and when shifting. When i got my car back all the tranny lights where off but shortly after they came back again.
He told me it could be a sensor screwing up or the tranny going bad... His advice was drive it till it gets bad then bring it back for another check or to sell it ASAP
Marka
22
09-11-2016 12:09 AM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
