What size socket for rear hub nut?
Old 09-10-2015, 10:45 AM
iownme's Avatar
Default What size socket for rear hub nut?
About to replace a rear wheel hub and bearing and need to know what size socket for the hub nut.
Also anyone know torque specs for hubnut and the hub bolts?
Old 09-10-2015, 03:13 PM
dwclapp's Avatar
iownme: You'll need a 32mm socket. A good impact wrench makes the job much easier. The part number for the replacement nut is C2S46889 - you're not supposed to reuse the old one. I got them for ~$12 each on eBay. Tighten to 270 Nm / 200 ft lbs.
Good luck.
Old 09-11-2015, 02:57 AM
iownme's Avatar
Good luck.
Thankyou :@)
Forcedair1
05-14-2023 03:28 PM
jagent
09-12-2015 01:40 AM
RaceDiagnostics
09-07-2015 07:28 AM
Joey T
09-03-2015 05:31 PM
innzane
09-02-2015 10:08 AM
Quick Reply: What size socket for rear hub nut?
