What is this squeak?
Received 3,901 Likes
Bob, does the squeak go away when you apply the brakes or does it go to a solid squeak? If applying the brakes causes it to change, then odds are your pads are getting significantly worn and you need to replace your rear pads. If the noise does not change, then odds are you are looking at a bad wheel bearing.
