What type of coolant to use?
Whoever said USE ONLY DEX-COOL is wrong
Read this thread.. https://www.jaguarforums.com/m_68720/tm.htm
All that post says is YOU use Jag Coolant and Brake fluid.
What is the difference between Dex-Cool and the Jag coolant
or DOT4 brake fluid and Jag Brake fluid?
This article says Dex-Cool is OK:
http://jagmotorproject.blogspot.com/...al-fluids.html
Do I need to use Jag air in my tires too???
The following 2 users liked this post by JagXV6:
Amy Sansing (02-19-2021),
speedwaymike (10-08-2020)
ORIGINAL: JagXV6
![EEK!](https://www.jaguarforums.com/forum/images/smilies/eek.gif)
If you want to risk your coolant system which is fussy anyways, with anything other than JAG COOLANT then go for it, it's your car not mine and you'll be the one paying for the mistake..Saving a few dollars on the Dex Cool vs paying out later for a new radiator, heater matrix, water pump and other coolant system components because you used something that will eat the insides out, make no sense....It is known that Dex Cool actually is detrimental after a while to the coolant systems of even GM cars.
As I said before and it's on the label of the bottle..the chemicals are different in the JAG COOLANT than the Dex-Cool..WHY?..I don't know, but obviously there is a difference for reasons mention above.
Well according to the JAGUAR TSB listed below, Dex-Cool is OK to use:
http://www.wwwboards.auto.ru/jaguar/5301.html
It calls out HAVOLINE Extended Life Coolant as a Recommended fluid
which is the same as Dex-Cool.
Of course anyone is welcome to use what ever they want.
This is why I caution the use of anything else..but perhaps with proper flushing, one might escape problems..
http://townhall-talk.edmunds.com/direct/view/.ef143e0/0
#7 of 23
by 0patience
Mar 04, 2003 (5:06 pm)
If your vehicle did not come with Dex-cool, then[/b] if you flushed it really well, you may be okay.
Dex-cool and other coolants[/b] do not mix. They[/b] coagulate and form a nasty gel that likes to build up in the[/b] worst possible places, like heater cores and pockets in the[/b] head.
Dex-cool is[/b] advertised as[/b] an extended[/b] life[/b] coolant[/b], but read the[/b] fine print. I will also recommend replacing the[/b] coolant[/b] every 3 years, amazingly enough, that is[/b] the[/b] same[/b] interval recommended by ethylene glycol manufacturers.
I drained and refilled my coolant system and I am certain that a lot was left in the block, as I needed less than the fill specs called for from empty to refill it..So bottom line, if you are doing this to the X, make damn sure you drain and flush the system to make sure all of the JAG coolant is out..
#7 of 23
by 0patience
Dex-col or any coolant that is compatible/suitable foraluminum is what you need to be looking at. The jag engine is aluminum as well as the heads. Using the old coolant from the 90's is not good.
Also when adding water to the coolant for that 50/50 mix (if not already premixed) use distilled water, prevents the build up calcium.
hope this helps.
hope this helps.
I use havoline extended life in my xk. I also read somewhere that any extended life afreeze will work in our newer jags. In my opinion, there are other fluids that are much more sensitive and should be watched more carefully than the antifreeze. thats right, you know what i'm talking about.
Unless you can open the engine drain plug (hidden by the oil filter and hard to remove) you really can't drain the X-Type coolant system. Flushing leaves a lot in the engine.
I think the whole "Jaguar" fluid issue is overblown. Good aftermarket products are good enough. Prestone meets ESE-M97B44-A (JTIS spec) and if it meets the spec it meets the spec.
The radiator is no problem, it's the engine. The hot and cold lines are along the top of the engine and the water pump is external and high, so when you open the drain plug you don't drain the engine.
Aarcuda (10-08-2020)
Don't know the exact plumbing on V8 engines, but if you have a front of engine mounted water pump the engine block can drain more completely. You use the WP suction line to drain the block. The X-Type engine has the WP at the back of the front cylinder bank high up. When I drained my engine I could only get about 5 of the 8 litres out. So you want to be careful about adding rad flush and filling it with plain water.
I’m currently on jaguar number six looking for number seven, so I’ve learned a few things over the decades! If you have a 2000 or newer (Including some 99’s) your coolant recovery bottle will have a sticker on it (Unless it’s been removed) that tells you to use the Ford spec (WSS N97B44-D. Remember Ford owned Jaguar for a while and even now owned by Tata motors they still use a lot of Ford specs.) the reason for that is that is OAT-organic acid based. Any other coolant can clog or damage your engine and even affect the electronics. If jaguar wanted you to use DEX they would SPECIFY DEX!
Mechanics can be like doctors; they’ll recommend whatever the sales person told them to recommend! If it didn’t matter what kind of coolant you used there wouldn’t be so many different types and manufactures would not specify a certain type or your vehicle!
Do you put diesel in your gasoline engine or 85% ethanol?!? Chances are you don’t & there’s a reason for it. Same thing goes for all the fluids in Jaguars!
