What is your MPG?
2003 3.0 Auto AWD 13mpg
Just changed out the Fuel Filter and this is my first tank it seemed to improve slightly. I bought the car with 105k I’m at 115k I’ll be changing Spark Plugs Clean MAF Sensor. Clean Throttle Body Change Upper and Lower Intake Gaskets and Valve Cover and I’ll see where this ends up. Car was in bad shape when I bought it but making its way back
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
I've got the 2003 2.5l AWD with a manual tranny and put mostly highway miles on the car...the drive to the office has been shortened but is still roughly 30 miles each way. The odometer is just shy of 160K miles.
I don't have the lightest of feet and tend to see somewhere around 24MPG. The managed lane is a posted 60MPH but on at least one direction each day, it is not uncommon to run closer to 80-85MPH. On the drives to Austin from the Houston area (about 150 miles), I am usually running 75-80MPH with few stops.
How much is gasoline there? Is diesel fuel cheaper? Diesel fuel is more expensive in USA, that is why diesel cars are not popular.
I very nearly bought an older Jaguar V8 in immaculate condition. As clean underneath as on top. Problem was the fuel consumption. Guys wife said you could watch the fuel gauge needle drop just getting it out of the garage.
Saw him later and he had sold it for £300. A truly magnificent low mileage motor. Fuel costs here really are dreadful.
We in the Uk have the economical Diesel engine cars which to aid air pollution have a DPF "Diesel Particulate Filter" fitted. This to clean up the emissions somewhat. Problem is the filters are prone to clogging up which can be an expensive exercise. To keep the filter clear one needs to go for a nice long fast drive. Which of course adds to pollution. CRAZY INNIT?
Given the increased fuel mileage with diesel, the price point right now makes it about a break-even proposition. I recall the spreadsheets on one of the truck forum to determine how long one would need to keep the vehicle in order to reach a break-even point for the added cost of the PowerStroke. Of course, back then, we could get diesel for under 70 cents a gallon while regular unleaded was over a dollar. Now the spread has gone the other way, with diesel being ~60 cents more per gallon near the house.
Perfect gas/air ratio is 14.7
Worst is probably 12.3. If ratio goes lower, spark plugs will not work. This is simplified theory.
Carburetors have different fuel systems (idle, mid range, power, pump). If one of the systems is really messed up, other systems can clean plugs.
Old Jaguars (1976 XJS) had fuel injection w/o o2 sensors, so MPG could be like carburetor cars have.
On this side of the pond, the type of petrol(ium) we put in our non-diesel tanks is called "gasoline" (92 octane, as the sticker recommends), which has hovered around $3.50 per gallon for years here in New York.
Over the course of ten years in my 3.0L AWD - mostly suburban, a little highway, I have never managed more than 16-18mpg on average.
3.0L petrol, automatic, 167k miles.
For a long time it was about 24.5mpg. Probably 80/20 highway vs in-town driving. I am not a "spirited" driver generally - I've got 100k miles on my rear brakes and they are just wearing out now.
Lately I have been getting about 21.5 mpg. Going to have the spark plugs replaced - never done before and I suspect it will help. Also, may replace fuel filter myself.
