wheel bearing help!
RE: wheel bearing help!
I've never seen an IPK switch languages by itself. There is a procedure to switch the language manually with some button presses on the headlamp switch trip computer buttons. I looked for it Friday and asked all the other techs if they could remember the procedure(not very common request) and we couldn't find it anywhere. Maybe one of the other techs here can remember the procedure, otherwise the search will continue on Monday. If all else fails it can be reset with the IDS at a dealer.
Well mystery solved. All I needed was a direction to go in and after looking around a bit I figured out how to set it. Pretty simple goes as follows
1) Hold in m/km button by the headlight switch and turn the key to position II. A language selection should appear.
2) Press m/km button to cycle through languages.
3) Press A/B button once desired language is on the screen.
Richard_gib
09-12-2015 07:08 PM
